BricsCAD Mac DCL dialog error
Hello,
I have a LISP routine which uses a DCL dialog, created for OtherCAD 12 years ago, works perfectly in BricsCAD for Windows.
On latest BricsCAD for Mac, it stops with an error :
5: syntax error - unexpected symbol ':'
which is strange because ':' is part of the standard DCL syntax, I really don't see what I could
use instead (has it something to do with the fact that the colon was the Mac's folder separator in ancient times ?),
and I haven't found anything in the LDSP on that subject.
Thanks for any insights,
Fabien.
The warning most likely means the symbol occurs in an unexpected position. Can you post the DCL?
@Roy Klein Gebbinck said:
The warning most likely means the symbol occurs in an unexpected position. Can you post the DCL? -
Well, I've found the culprit !
The problem was the presence of extended chars (french accents) in the previous line.
The file was encoded with Windows 1252 or ISO-8859-1 (which is pretty normal since it was written in notepad).
Saving it in UTF-8 (without BOM) solved the problem.I don't know if it qualifies as a "bug" in BC for Mac, but other people might encounter the problem someday,
in a company where PCs and Macs share the same DCL file.Fabien.
I use notepad ++ and often just paste into plain notepad to stop bugs like this. Using word is a big No NO writing lips code as so many hidden characters get created so again paste to notepad from WORD and then save.
I use word as you can do replace using end of line. Notepad++ has it also.
Dear Fabien,
in a HexEditor I found several sequences :
0x09 0x3A == .:
(dot for character without visual representation)
so that 0x09 character originates from a) non-ANSI/ASCII editor ? b) copy/paste using such editor ?Otherwise, saving as ANSII file should also work on Linux/Mac (incl. French characters), as long as the Linux/Mac is configured to use French code-pages ...
many greetings ! -
@Torsten Moses said:
Dear Fabien,in a HexEditor I found several sequences :
0x09 0x3A == .:
many greetings !The DCL file has been created/edited with Notepad or Notepad++. Maybe some code have been pasted from the Web. However,
replacing accented chars with non accented ones ("é" -> "e") also "solved" the problem, that's how I thought about converting to UTF-8. -
Dear Fabien,
it might be possible, that NotePad/NotePad++ automatically switch to UTF-8 if they encounter any character above 0x7F :-(
I encountered this as well with UltraEdit (there, such automatic switch can be disabled in Settings);
saving a file with characters above 0x7F in ANSI file is fine - as long as it is used on a system with same code page :-)So keep an eye on NotePad/NotePad++ whether it switches to UTF-8, and/or force saving as ANSI then.
many greetings !
Howdy, Stranger!
