Push pull from a reference point
I want to push pull a solid from say 75.38 to 90 without having to calculate the distance, how would I go about that? In AutoCAD I use the command FROM, select the base of the solid & enter 90 for the distance, but I can't seem to do it in Bricscad. Thank you.
  • Try using the Push/Pull command on a 3D solid and press the Tab key while the command is active. It switches the input modes if Dynamic Input is ON from Extended length to Total length.
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
