Two questions before I BricsCAD trial-
I intend to purchase Lite, but after a trial use. The trial includes full BricsCAD, so I can't confirm The manual tends to lump the two products together.
- Does the Lite version include creation of new pdf prints/files? Not just manipulation of imported pdf files.
- Does Lite import DXF files, and can it produce the same?
~ This venue seems out of place for this type of questions.....
0
Yes, Print to pdf and handling dxf files (open, create) is supported in the Lite version.
To check the availability of a feature in a certain license level, run the SETLICENSELEVEL command. Choose a license level, then restart BricsCAD.0 -
Thanks Louis! I will remember the command.
0
