Copy DWGPROP custom properties between files
Hallo
I have created a template with a titleblock and I added a series of custom properties with DWGPROP > CUSTOM panel (I added Items such as Forma, scale, date, project name, etc...) which I can change using sheet manager.
Template is fine if used as starting drawing, but when I try to import the titleblock from a template in a new layout, the properties are not imported.
In autocad you can use the PROPULATE (Express Tool) command.
Is there a way to inherit or transfer these properties ?
Thanks
Luca
If you were to consider third party add-ons, DotSoft's ToolPac contains tools to:
Copy: Copies the DwgProps content to the clipboard for pasting into other open drawings.
Paste: Pastes selected DwgProps fields from copied content to the current drawing.
Set: Sets specified drawing properties information in multiple selected drawings. A lookup table (copied from a spreadsheet) can be used to supply unique values for each drawing!0 -
Hello,
there are the "ExpressTools for BricsCAD", a 3rd party freeware by Martin Drese;
you can download from
https://www.cadwiesel.de/cw_download_01.php?id=266
should work then :-)
many greetings !0 -
Thanks Terry Thanks Torsten
both of you for the suggestion I will try both options.regards
Luca
0
