Editing a parametric block via the API
                    Hello,
I´m trying to automate a task where I have to insert a Block and then edit attributes and the parameters contained in that block. I know how to insert a block and edit the attributes but I can´t find how to edit the parameters.
Does anyone know how to edit parameters in a block via VBA/Lisp or .Net?
I hope you can help me!
With kind regards,
Robert
With kind regards,
Robert
0
            There is a BRX C++ API for it provided by AcConstraints3d.h, but as I recall, that API is also available via .NET ...
for LIPS it is not possible (yet ?).
hope this will help ?
many greetings !0 -
            Hello Torsten,
Thank you for pointing me in that direction, I´ll go check that out!
With kind regards
Robert0 -
            By parameters are you talking about a dynamic block ? If so just look at www.lee-mac.com dynamic block properties.0
            By chance another topic from 2019 was bumped up and contained what I was looking for.
Just posing it here I anybody else has this problem.
https://forum.bricsys.com/discussion/35199/get-or-set-constraints-with-visual-lisp-vba#latest0
