Bug in Layers Dialogue window ?
hi all -
In the Layers main box (in drawing explorer), I try to change a layer linetype (e.g. >> from Continuous to Hidden), and it just won't open the flyout selection - instead the 'cursor' snaps right back to layer's name.
Other layer's properties (color, state (lock/freeze/ etc.) - works OK.
Plus - the above seems to happen at a certain file, while NOT in others.
is it a bug ?
is it something related to a drawing definition ?
Regards,
Assaf
is it a bug ?
Regards,
Assaf
0
Hi!
This might be a bug or maybe something corrupt in the file. You could consider submitting a Support Request with Bricsys. To submit a Support request login to your Bricsys account and access this link here: New support request
Additionally, you could consider uploading the file (or a simplified version of it) here as well, so people in the community can take a look at it.
Billie0 -
thank u billie -
i'll put the file soon.
meanwhile, i manged to work around the problem using the LAYERS Panel (rather than the Drawing Explorer window.
regards,
Assaf0
