Layer properties
Hello, everybody.
Is there a possibility that layer properties opens in separate window instead of appearing in side panel.
That happens even when I set it off of panels.
Thank you.
Thank you.
0
Hi dusan_savic,
Yes you can - simply drag your layers icon towards your modelspace (undock) it. It should then exist as a floating dialog.
Kind regards
Kin0 -
Thank you, very much.
0 -
You can also lock the panel to the other side of the screen.
0 -
Thanks, Robert, that is also good to know... but I need it in separate window in order to see all columns of layer properties without stretching.0
