Link Object Properties to Annotations or BIMTags
I wish to know if possible link Properties to Annotations or BIMTAG
for example:
link Annotations to Polyline Length, if my polyline lenght is 1000 then Annotations should shows "1000" and if length change to 2000 then the Annotations should hange anutomatically to "2000"
for example:
0
That is done by using Fields use mtext fields are an option, little icon button, common use is length and area. Select object and follow the questions.
Just google using fields Bricscad or Autocad
0 -
thanks, field looks like AutoCAD solution, but is there any method to link any property with the annotation? I mean is probably, given that AutoCAd too, in BC does not exist field for all properties or is not possible create other custom fields.
in AutoCAD MEP is called Property Set Data the custom properties than are possible link to "Mv-BLocks TAGs" like BIMTags, and is possible to export to IFC such data to coordination with others.0
