Commands - C# - Entity or Selection Set as Parameter
Hello, everyone.
I'm trying to execute a command using C# in BricsCad Pro V22 x64. The problem that I'm encountering, is happening when I try to send a Selection Set or a Entity to a Editor.Command as a parameter.
It works in Autocad with Entity and Selection Set (https://www.keanw.com/2015/08/passing-autocad-objects-to-commands-called-via-net.html), but it does not work in BricsCad. When I run the code in Brics, it shows the error: "unable to recognise object". Then I must manually select something. This is the code I'm using:
using (Transaction tr = db.TransactionManager.StartTransaction())
PromptEntityResult selRes = Editor.GetEntity("Select something:");
if (selRes.Status == PromptStatus.OK)
Entity ent = tr.GetObject(selRes.ObjectId, OpenMode.ForRead) as Entity;
Editor.Command("._REVCLOUD", "_E", ent, "");
Does anyone know what can I do? It looks like that BricsCad doesn't support that way of calling a command with a Entity or Selection Set. But there must be one or another way to do that. The ideia of the code is get a entity (or many) and turn it in a revision cloud. Thanks in advance.
0
Create a SelectionSet and use it to call the REVCLOUD command
var ss = SelectionSet.FromObjectIds(new ObjectId[] { selRes.ObjectId });
ed.Command("_.REVCLOUD", "", ss, "");0 -
Editor.Command("._REVCLOUD", "_E", ss, "");0
Thanks for the answer. But I still receive the message: Unable to recognize input. Then I must again select something. I used the following now:
[CommandMethod("try_cloud")]
public static void cloudTest()
Document docum = Application.DocumentManager.MdiActiveDocument;
Database datab = docum.Database;
Editor editor = docum.Editor;
using (Transaction tr = datab.TransactionManager.StartTransaction())
PromptEntityResult selRes = editor.GetEntity("Select something:");
editor.Command("._REVCLOUD", "_E", ss, ""); //"Unable to recognize input" message received
}0 -
Try this code, it works for me with no errors generated !
[CommandMethod("RVCL")]
SelectionSet ss = SelectionSet.FromObjectIds(new ObjectId[] { selRes.ObjectId });
ResultBuffer rb = new ResultBuffer();
rb.Add(new TypedValue((int)LispDataType.Text, "_.REVCLOUD"));
rb.Add(new TypedValue((int)LispDataType.Text, ""));
rb.Add(new TypedValue((int)LispDataType.SelectionSet, ss));
Bricscad.Global.Editor.Command(rb);
0 -
Sorry typing error correction needed....selection set creation must be within the IF block......
}0 -
Thank you, so much. This works perfectly. No erros.0
