Drawing revision status block - attributes and suppression
Hi all,
I'm attempting to create a block containing attributes, visibility states and suppressions to insert into my titleblock that will allow for easy updating when a new plan revision is issued. I've followed what I can on the topic of suppressions but the block is not behaving as desired. Essentially I want to leave the attributes associated with successive revisions as invisible until such time as they're needed, then I can turn them on and modify them accordingly.
I've attached the block in question and would appreciate any time taken to have a look and let me know if and how it's possible to achieve what I'm after.
Cheers
Cheers
0
I dont play much with dynamic blocks but have a client one that has like 10 visibility states and has 2 3 or 4 attributes depending on the state some 30+ attributes. So make new atts for each state.0
