CTRL+Z Crashes Briscad, no sv$ files
                                  in Other
                    Hi there, I'm trying Briscad and after a CTRL+Z which I use to undo the last operation in Autocad, it roll back a lot of actions and crashes (gets closed).
I was expecting anyway to get a "restore last unsaved file" which is missing... There is nothing sv$ in the temp folder. Why?
I've looked in the windows registry and found that error:
Name of the application that generated the error: bricscad.exe, version: 22.2.5.0, timestamp: 0x629a0e7e Name of the module that generated the error: ucrtbase.dll, version: 10.0.22000.1, timestamp: 0x00e78ce9 Exception code: 0xc0000409 Error offset 0x0000000007dd7e Process ID that generated the error: 0x4280 Start time of the application that generated the error: 0x01d8c8dbc42ed7eb Path of the application that generated the error: C:\Program Files\Brics\BricsCAD V22 en_US\bricscad.exe Path to the module that generated the error: C:\WINDOWS\System32\ucrtbase.dll Report ID: d514ade1-ea07-4c3d-8fed-0625139b2926 Full name package that generated the error: Application ID related to the package that generated the error:Thanks, Dennis
0
            Hi, I am pretty sure that the plug-in I bought is the problem here.
https://forum.bricsys.com/discussion/37795/undo-only-last-action#latest0
