3D polyline linetype display
Moving from Civil3D to Bricscad.... Is there a method to display linetypes with 3d polyline??? Is this coming in a future version? Is there any method to draw arcs in 3d, like C3D feature lines?
-1
You can draw an arc in 3d but you have to use a UCS to do it setting a plane that matches start and end points.0
You can transform the 3Polyline into a Group or a Spline to show the LINETYPE
Regards
Jochen
www.black-cad.de
www.ant-ares.de0
