Dimensioning Issue
                    I'm new to BricsCAD and have been a user of AutoCAD for years.  When I dimension something that is not perpendicular from my original snap point, the dimension line becomes an angled dimension.  What is the setting to avoid this?  Thanks.
                0
            Are you using the DIMLINEAR command? The behavior you described sounds like what I get with the DIMALIGNED command.0
            Or this happens by using the new top alternativ DIM . Just don't use it creates more confusion0
