(command "-vpoint" "1,0,-1") return Nil (failed)
Hi.
I tried changing the viewpoint through a command ((command "-vpoint" "1,0,-1")) in a lisp and I'm getting Nil as return.
is there a way to use "-vpoint" command in a lisp?
thanks,
aridzv.
*edit:
for now I'm using a saved view by the name of "TOP-FRONT-RIGHT" and load it with this command:
(command-s "-v" "Restore" "TOP-FRONT-RIGHT")
thanks,
aridzv.
*edit:
0
Posted elsewhere ?
(command "-vpoint" "1,0,-1") removed the extra brackets.0 -
The extra brackets is not used in the code...
And for your first question - yes.
Since you and others insist it should work Maybe it is a bug - I'll send a support request.
Thanks anyway.0 -
(command ...) always returns nil, it does not mean the function or the command failed.0
@Roy Klein Gebbinck
Hi Roy and thanks for the reply.
the command dosn't change the view point.
about the Nil - it is true what you wrote,I've been explained erlier that if I add (princ) after the command in the lisp it will not return Nil.
but still - when I run the command,both from command line and from a lisp it dosen't change the viewe point...
regards,
aridzv.
EDIT:
I must add that if I type the command in the command line an maually type the values it dose work...
I just can't make it work through a lisp...0 -
In V18
(command "-vpoint" "1,0,-1")works.0 -
so in v23 it is probably a bug (and also in V22...).Roy Klein Gebbinck said:In V18
I've sent a bug report to the support.
in the mean time I aded views to my template file (named "TOP-FRONT-RIGHT" and "REG"),
and then I use lee mac StealV1-8.lsp to load them to my drawings from the ON_DOC_LOAD.lsp and ON_START.lsp,
and then change them from a lisp this way: (command-s "-v" "Restore" "TOP-FRONT-RIGHT")
0 -
the problem solved by bricscad support team.
apperntaly my user profile was currpted in some way (maybe to much lisp experimants...
I've re-load the default user profile and the command is working.
0
