DWG Crash
                    Has anyone having problems with DWGCOMPARE? It crashes every time I try I select the DWG to compare to
                0
            Hello,
The behavior reproduces only if RUNASLEVEL system variable = 0 or 1 . (BricsCAD uses a Lite or Pro license)
The crash does not reproduces with the same BricsCAD V23 version if RUNASLEVEL = 3,4 or 5 for me.
There is a known issue about DWGCOMPARE crashing BricsCAD under Lite or Pro license level and it will be fixed in a future release.
As a workaround, you can use DWGCOMPARE in BricsCAD V22 in the meantime.
Have a nice day!0 -
Nice one mate! Works fine in v22. Rarely use compare so I don't mind this for the time being.Hello,
Have a nice day!0
