bug in TRIM two POLYLINE
I draw two close polyline and trim elementstrim random elements poly line !!!???sample two rectangle and trim they hmmm???
Can you please explain clearly what you want us to do to reproduce the problem you experience? Or preferably, enter a support request and attach a small sample drawing that illustrates the issue? We will be glad to investigate.Kind regards,Hans De Backer
0 -
Dear Arkadiusz,thanks for the sending the illustrative drawing, this really helps. The reason you don't get the desired result is that you select both rectangles as trimming (cutting) elements and then again select one of these rectangles as an element to be trimmed away. To obtain the result you indicated, start the TRIM command, select one cutting rectangle, Enter, and select the rectangle to be partly trimmed by picking a point on it that lies outside the cutting rectangle: the rectangle will be trimmed so only the part inside the cutting rectangle remains.Kind regards,Hans
0 -
ThankOnly random trim when I select one polyline.I post drawing sample detail problem. This problem all version Bricscad
0 -
Arkadiusz,thanks for sending a second drawing, though I want to repeat my request to enter this as a support request, which simply is the preferred way to enter a request for supporting you with a problem...I tried out all five scenarios you describe, using builds v4.1.0006, v4.1.0040, v5.0.0008 and v5.0.0010 which is about to be released. These are US-English versions. They all perform correctly and give the desired result that you indicate.Communication would be easier if you had entered a support request and filled in the required information about the version nr AND the locale (=the language) of the build that you experience this trouble with. Now I can only guess and waste time trying out different builds..Kind regards,Hans
0 -
I work in windows xp, BricsCad Pro GB 5.0.0008GBonly I work dwgcodepage=ANSI_1250 and tablet Wacxom, my system work correctly.I had any problem when I install otcher versin BricsCad, when I must clean registry,that new version instaling and not problem.
0 -
Bug is when I Trim - select secend polyline /secend drawing/ to trim first polyline in drawing.number entities in drawing decyding this bug becasI trim select first to trim secend to OK hmmmby
0 -
my system :Windows XP Pro SP1 PL /Poland/ + all updateDirectX 9.0bBricsCad Pro GB 5.0.0008GBit's all in system
0 -
Not correctly triming two polylineBug is when option " Use implied edges to Trim/Extend" is on .I work most often "edges Trim" uff to end looking for bug
0
