How to compile brxSample
I'm trying to compile the sample BRX program from BRX SDK V23.
It is giving the following error messages:
1>F:\MagiCAD-Dev\BRXSDK_V23\samples\brxSample\StdAfx.h(64,13): error C3510: cannot locate dependent type library 'axbricscaddb1.tlb' {88161633-e57e-4fce-a6f3-94ffea20879a} v.23.0
1>F:\MagiCAD-Dev\BRXSDK_V23\samples\brxSample\StdAfx.h(64,13): fatal error C1083: Cannot open type library file: 'c:\brxsdk_v23\inc64\axbricscadapp1.tlb': Error loading type library/DLL.
I'm running VisualStudio 2019 v. 16.7.7 in Win10 with WinSDK 10.0.19041.685 installed
I also tried manually registering the mentioned dlls in Bricscad's program directory.
axbricscaddb1.dll and axbricscadsm.dll register just fine, but
C:\Program Files\Bricsys\BricsCAD V23 en_US>regsvr32.exe axbricscadapp1.dll
fails with message "failed to load". VS tool Depends.exe tells that VCRUNTIME140.DLL is missing required function "__C_specific_handler"
Can you please instruct me how to compile the sample ?
0
First, fix the configuration weirdness, should be debug, and not fulldebug
Then add a system variable pointing to the SDK
0
