text cannot double click, but after double click it pause.
Some Text/Mtext cannot edit in place when double click, but after double click it pause with selection cursor, the Text/Mtext can be edit by clicking the direction key but after click direction key it will become other type of text style. is there any solution for this? some trial end up error on vla-editinplace null not remember the full sentence.
for now we only using match properties to reset the text style. but if drawing is to big become time consuming.
thank you.. hopefully it can solve this.
0
wow bricscad have no people of expertise to answer this.. lol... this still unknown error and unsolve yet.0
Did you provide detailed information about the issue to the support team via support request? You can do it here: https://boa.bricsys.com/protected/support/NewSupportRequest.do0
An alternative to a one-by-one use of Matchprop would be to use QuickSelect to select all the texts & mtexts, or maybe all the ones that use a certain text Style, and change their Style all at once in the Properties panel, or with a custom version of Matchprop that selects the target entities first so that they can be pre-selected.ahtenk05 said:....for now we only using match properties to reset the text style. but if drawing is to big become time consuming.....
0 -
it is about in place editor.
some drawing cannot do in place editor after activate it, still cannot work.
it open the text/mtext but when typing a new word it dont anything.
need to hit the direction key either left or right button, then it can start to edit the text/mtext.
so require another step to edit text/mtext0
