Lisp routine to change table column width and text size
A couple of possible solutions, google for examples.
SetCellTextHeight
SetColumnWidth0 -
Will have a look thanks!0
I had a breakthrough on this, thanks to ALANH's help! I'm sharing my code, enjoy! At first it was adding the new row data as a very small text height, now I can actually influence the text height (aka size font size etc etc etc).
; Set the text height of the cells in the new row
(setq cell 0)
(repeat 3
(vla-SetCellTextHeight tableObject numRows cell textHeight) ; Set the cell's text height
(setq cell (1+ cell))
0 -
Another question I have is on the data I'm getting from the 1st cell of column 1. It's of the same table except it goes {1,2,3,4,5,6,1} for the data in that 1st column worth of cells... Anyhow, what's with the extra formatting looking info of "{\fArial|b0|i0|c0;" before the data that will show in the cell?
Select table:
Entity type: ACAD_TABLE
1st row = {\fArial|b0|i0|c0;Line #
2st row = {\fArial|b0|i0|c0;1
3st row = {\fArial|b0|i0|c0;2
4st row = {\fArial|b0|i0|c0;3
5st row = {\fArial|b0|i0|c0;4
6st row = {\fArial|b0|i0|c0;5
7st row = 6
8st row = 1
Printed all cell data from the first column.
Is there a way to add that prefix worth of formatting details to the cells I'm creating?0
