Colorbook - not working in 23.2.03 German
We have a colorbook, used in the last version of Brics in 20, 21, 22.
Now, in version 23.2.03, we
- find the colorbook in our color selection
- see all the entries with names and RGB definitions
- can select it
- but nothing happens: The selected color is not applied to the element, and their is no error message.
What can be wrong here?
Thanks and regards
Peter
- can select it
Thanks and regards
Peter
0
V23.2.05 includes a fix for color books, hopefully this is the same issue you are talking about. You can download it and try the current behavior.0
Thanks Osina
in the meantime I posted it also in German Forum
https://ww3.cad.de/foren/ubb/Forum481/HTML/000670.shtmland a user confirmed the problem for 23.2.05 too.
Edit:
and with 23.2.05 it seem to be OK now.0 -
Hi Peter, it's good to hear your problem is solved! I've seen on the mentioned German forum that another user's issue is related to encrypted color book, they are not supported in BricsCAD at the moment.0
