PARAMETER VALUE AS DIMENSION TEXT
I'm new to Bricscad but long time Acad user.
I'm looking for a way to show a user parameter value as the text in a dimension (overriding the actual text dimension). If that's not possible, I'm open to using a standard text or an attribute, I can't seem to locate user parameters in the attribute definition command (ATTDEF).
BricsCAD pro V23.
-Sorry for the double post, the forum system indicated it could not post but it did
BricsCAD pro V23.
0
A similar question was raised 18 months ago, and I would still like to know the answer.0
This is really something they need to include as you cant even use the material in the part in your titleblock.0
Hi richardlmgm,
If I understood your question correctly, then you'll be able to get to your parameters using _FIELDs.
1. Create a new _FIELD and browse for Extensions > Extension Properties.
2. Select your parametric block
3. From the Properties Category choose Parameters.
All the best,
Billie
0 -
This only works of you have multiple parts in your drawing.Billie said:Hi richardlmgm,
All the best,
Billie
If you just want the parameters for the currently open drawing it is not possible.
Please fix.0
