layer table documentation
Is there any available documentation for how the data is stored in the layer table? I have found some code that accesses "layer" table but not only it contains quite less data than expected, it is also difficult to figure out how the (70.XX) key-value pair works. An example that I found in the table is ((0 . LAYER) (2 . LAYERNAME) (70 . 0) (62 . 6) (6 . CONTINUOUS)), but it doesn't seem to change at all when I change the layer from printable to nonprintable, and the flag (70.XX) changes value when the layer is locked/unlocked as well as frozen/unfrozen, so it is not a simple true/false value.
So, at the end
A ) is there any documentation for this table, or
B ) is there any other way to use LISP to list all the layers that are non-printable, frozen, and switched off?
So, at the end
0
I don't think this is very well documented, even by Autodesk. It is a bitwise flag. I understand this "flag" is an integer representation of a binary number, acting combined as a grouping of logical true/false operators. I found a couple of places that described the first few flags for the layer table:
- 1 is Frozen, 2 is Frozen on new paper space view ports and 4 is locked.
- the rest of the values will be 8, 16, 32 and 64 (binary 1000000).
- These can be added to give a unique combination of states.
0 - 1 is Frozen, 2 is Frozen on new paper space view ports and 4 is locked.
Using VL may reveal what you want this is a dump of a couple of layers, the grated pit is set to no plot.
(setq LayerTable (vla-get-layers (vla-get-activedocument (vlax-get-Acad-Object))))
(vlax-for lay LayerTable
(if (= (vlax-get lay 'name) "DEFAULT")
(vlax-dump-object lay)
; Property values :
; Application (RO) = #
; Color = 7
; Database (RO) = #
; Description = ""
; Document (RO) = #
; Freeze = 0
; Handle (RO) = "E3BF"
; HasExtensionDictionary (RO) = 0
; LayerOn = -1
; Linetype = "Continuous"
; Lineweight = 9
; Lock = 0
; Material = "Global"
; Name = "DEFAULT"
; ObjectID (RO) = 1064881392
; ObjectID32 (RO) = 1064881392
; ObjectName (RO) = "AcDbLayerTableRecord"
; OwnerID (RO) = 1062013728
; OwnerID32 (RO) = 1062013728
; PlotStyleName = "Color_7"
; Plottable = -1
; TrueColor = #
; Used (RO) = -1
; ViewportDefault = 0
nil
(if (= (vlax-get lay 'name) "DR_GRATED_PIT")
; IAcadLayer 6604e4c0 : TeighaX Interface of a logical grouping of data, similar to overlays.
; Property values :
; Color = 2
; Database (RO) = #
; Description = ""
; Document (RO) = #
; Freeze = 0
; Handle (RO) = "C7C1"
; LayerOn = -1
; Lineweight = -3
; Lock = 0
; Name = "DR_GRATED_PIT"
; ObjectID (RO) = 1064834032
; ObjectID32 (RO) = 1064834032
; PlotStyleName = "Color_2"
; Plottable = 0
; TrueColor = #
; Used (RO) = -1
nil0 -
For Plot you check the value for 290 dxf code.
With the 70 dxf code you can use boole to check for a setting
See here for documentation Layer (DXF)
Here is an example function to illustrate(defun LayerState (layername / layer laystat state) (setq Layer (tblobjname "LAYER" layername)) (cond (Layer (setq layer (entget layer)) (setq laystat (vle-cdrassoc 70 Layer)) (setq state (list (cons "Frozen" (if (= 1 (boole 1 1 laystat)) 1 0)) ; 1 = Frozen 0 = Thawed (cons "NewVPFrozen" (if (= 2 (boole 1 2 laystat)) 1 0)) ; 1 = New VP Frozen 0 = New VP Thawed (cons "Locked" (if (= 4 (boole 1 4 laystat)) 1 0)) ; 1 = Locked 0 = Unlocked (cons "Xref" (if (= 16 (boole 1 16 laystat)) 1 0)) ; 1 = Xref 0 = Not a Xref (cons "XrefRes" (if (= 32 (boole 1 32 laystat)) 1 0)) ; 1 = Xref resolved 0 = Xref not resolved (cons "Referenced" (if (= 64 (boole 1 64 laystat)) 1 0)) ; 1 = Yes 0 = No (cons "Plot" (vle-cdrassoc 290 Layer)) ; 1 = Yes 0 = No ) ) ) ) state )
Regards,
Jason Bourhill
BricsCAD V23 Ultimate
CAD Concepts0
