Block parameter with block attribute definition
in 2D Drafting
I created a block with a flip parameter.
When I add an attribute definition, it no longer shows the Block parameter as an option. It only shows the attribute definition under properties. Is this the normal behavior?
How do I add an AttDefenition and a block parameter?
0
It would be helpful to see the drawing with the attached block. If you don't want to share this publicly you can submit a support request.
https://boa.bricsys.com/protected/support/NewSupportRequest.do?categoryID=1460 -
Thanks Rose. I figured out how to do it.0
