Can I use license for latest version?
Permanent license was purchased for V.20 but when trying to active V.24 using the same license, did not work. It had error code -1021. Had to deactivate on the old laptop to install on the new one, so downloaded the latest version of BricsCAD.
Or, do I have to use V.20 for the license to work?
0
You have answered your own question you purchased V20 if you want V24 then must upgrade. Hope to go to V24 soon once some clients pay.0
