right - click menu lags
Hi,
I use a customized right-click menu. When I work with a file on my local computer, the right-click menu opens immediately.
However, when I work with a file on the network, the right-click menu is delayed by a few seconds (except when I right-click with the shift key). Does anyone know how to solve this problem?
0
maybe this is related to the SHORTCUTMENUDURATION system variable0
Thanks for your answer, but SHORTCUTMENUDURATION has no effect on this problem.0
What about the Setting immediately above SHORTCUTMENUDURATION? The 16 bit of the SHORTCUTMENU variable.0
