Tab option cycling during trim command
Just a heads up that support is working on clearing this up. In V24 hitting the tab button during the trim/extend commands to cycle thru entities wasn't working for some reason. Anyone else run across this yet?
0
I can confirm I also noticed this, but I was using trim within a lisp routine so hadn't got round to seeing if it was the same in the native command.0
