No longer Able To See Polyline Lengths In Realtime?
Hi SticksAndBrics,
You seem to have DYN (Dynamic Input) turned off at the bottom of the screen, in the status bar. DYN and DUCS are turned on by default when you first start BricsCAD.0 -
It seems you turned off dynamic input, click DYN option in the Status Bar to return it.0
God bless both of you!!!
All fixed, thank you
0 -
You are welcome :-)0
