.STB vs .CTB
I see the benefits of .STB methods of plotting-- more control of grayscale, colors or lineweights. However, .CTB method is simple and good enough for most of my work.My problem is when opening a drawing from an ariel survey company, it seems to establish my print options to .STB styles only. I cannot seem to gain access to the .CTB files. I notice that when youy use the wizard to create a new drawing, it wants to assign the print file method at the outset. My question is -- Is there a way to change the print method "on the fly"? Is there a config setting or system var that I can toggle?Please, anyone let me know if you can help.Any help would be appreciated
No, you cannot change the plot style policy on the fly or toggle it from CTB to STB or vice versa.The type of plot style used in a drawing is assigned when the drawing is created. If you need to change the plot style policy you must convert the drawing using the CONVERTPSTYLES command. See online help "Converting a drawing from .STB to .CTB file type"The system variable envolved is PSTYLEMODE which holds the type of plot style used by the drawing
0= use STB, 1 = use CTB.). However, this system variable is read only so you cannot use PSTYLEMODE to toggle from on mode to another.0 -
Thank you much.I didn't see it in the help file.
0 -
Type covertpstyles at the command prompt and it will convert the drawing to a ctb style drawing.
0 -
I feel that there is something missing in the CBT-file and that is plot scale.Why isnt that included. Especially batchplotting would benefit from this.No info from the Scale/View page is included.Now you always have to doublecheck.Its almost a step backwards.Patrik
0
