Bricscad v24 Crashes When Closing a Drawing
This actually started in v23, but v24 has gotten much worse. When I close a drawing, typically by pressing the X in the corner, Bricscad will crash and close other open windows. It does allow me to save them first. But it creates a crash_report.txt and date/date file in dmp format. LINK
Is there a fix, or a setting I might have incorrect?
0
Hello,
As this is about a crash, I suggest to write a support request here: https://boa.bricsys.com/en-eu/support/#77. Write the scenario and send the crash report and the dmp file, too.
0 -
Thanks, will do that.0
Same here, it really got worse with v24, I hope it gets fixed soon enough0
Same here.
Got even worse in V24.1.070 -
Same here!
in V24.1.07 it crasches almost each time I close a drawing0 -
I get this sometimes too.0
Please download BricsCAD V24.01.08 and see if this resolves the issue.0
