finding self-intersecting polylines and polylines with double vertices
Hello, do any of you know a lisp tool for finding self-intersecting polylines and polylines with double vertices, similar to the "selfintersect.vlx" tool from this page?
https://www.cadforum.cz/en/self-intersecting-polylines-and-polylines-with-duplicate-vertice-tip10926
Or is there another way to accomplish this task in BricsCAD?
The problem is that BricsCAD apparently cannot process *.vlx files, and I have not yet found a corresponding *.lsp file online that does this job.
I myself work with BricsCAD version 23.1.08 (x64) and am more of a user than a programmer, which means I can't program LISP.
I need a tool like this to be able to create correct polylines for grading in BricsCAD-Civil. I often have to import these from "geometrically inaccurate sources" such as PDFs. Then I have to check the lines for errors, otherwise there will be problems when creating the grading. By the way, it would be good if there was a warning when creating the grading when you select a polyline with self-intersection, not just a cancellation or "not working" of the command.
0
Too bad you’re not using V24, Python’s shapely has a tool for checking polygons
https://shapely.readthedocs.io/en/latest/manual.html#validation.make_valid
I’m not sure if it will catch all your issues, but in this case, it detects self-intersection and fixes it by creating MultiPolygon
Some sample code:
import traceback
from pyrx_imp import Rx
from pyrx_imp import Ge
from pyrx_imp import Gi
from pyrx_imp import Db
from pyrx_imp import Ap
from pyrx_imp import Ed
from pyrx_imp import Gs
from pyrx_imp import Cv
from shapely.validation import make_valid
from shapely.validation import explain_validity
from shapely.geometry.polygon import Polygon
def PyRxCmd_doit() -> None:
try:
db = Db.curDb()
filter = [(Db.DxfCode.kDxfStart, "LWPOLYLINE")]
ssres: tuple[Ed.PromptStatus,Ed.SelectionSet] = Ed.Editor.select(filter)
if ssres[0] != Ed.PromptStatus.eOk:
print("Oops {}: ".format(ssres[0]))
return
for id in ssres[1].objectIds():
pl = Db.Polyline(id)
sp = Polygon(pl.toList())
if not sp.is_valid:
#why
print(explain_validity(sp))
#fix
nsp = list(make_valid(sp).geoms)
for spl in nsp:
npl = Db.Polyline(list(spl.exterior.coords))
npl.setColorIndex(3)
npl.setClosed(True)#?
db.addToCurrentspace(npl)
except Exception as err:
traceback.print_exception(err)
0
