Undesired Text Style Removal now Non-Purgeable
                    Goal:
Find methods to help assemble a new LISP program or find an existing LISP program to perform the following:
Purge an undesired text style that is referenced by an object property or other data not visible and proving impossible to purge.
Please provide:
Links to and/or actual LISP programs that perform this or similar object PURGES.
LISP tips and/or instruction on links to methods to create a HARD PURGE (object style in use) LISP program.
Many thanks for reviewing this inquiry!
Clint
Please provide:
Clint
0
            Objects using that text style can be so deep to find maybe in a Block somewhere. I would start there. If The dwg has come from CIV3D it holds lots of proxy info there is a deletestyleandsettings in CIV3D need to run that first to purge stuff out.0
            Something that usually might be useful, although it doesn't use lisp, could be to use the Drawing Explorer.
With this, the text style to be deleted could be right-clicked and the option Delete could be chosen.
Further, there will be the option to either delete the entities using that text style or to keep those entities and replace their text style with another one.
0 -
            Not lisp, more on the advanced side, but you may be able to use filer to search for what’s referencing a particular style
Concept using Python in V24
found
import traceback
from pyrx_imp import Rx
from pyrx_imp import Ge
from pyrx_imp import Gi
from pyrx_imp import Db
from pyrx_imp import Ap
from pyrx_imp import Ed
from pyrx_imp import Gs
from pyrx_imp import Cv
def PyRxCmd_doit() -> None:
try:
db = Db.curDb()
style = db.textstyle() # cur style
ids = db.objectIds() # all ids
found = {}
for id in ids:
#this is it!
if id.isDerivedFrom(Db.TextStyleTableRecord.desc()):
continue
dbo = Db.DbObject(id) # kforread
snooper = Db.SnoopDwgFiler(Db.FilerType.kCopyFiler)
dbo.snoop(snooper)
for item in snooper.buffer():
if item[1] == style:
name = dbo.isA().name()
hwnd = id.handle()
if name in found:
found[name].append(hwnd)
else:
found[name] = [hwnd]
for item in found.items():
print(item[0], len(item[1]))
except Exception as err:
traceback.print_exception(err)
: DOIT
AcDbMText 6220
AcDbDimStyleTableRecord 25
AcDbDetailViewStyle 4
AcDbSectionViewStyle 4
AcDbMLeaderStyle 1
AcDbAttribute 3389
AcDbText 1174
AcDbAttributeDefinition 266
AcDbTable 2
AcDbTableStyle 6
AcDbTextStyleTable 10 -
            I appreciate your interest and all the great, useful ideas and code. In this case, a separate inquiry yielded a LISP solution directed specifically and solved the issue with this troublesome font.0
Hi Virgil,Virgil said:Something that usually might be useful, although it doesn't use lisp, could be to use the Drawing Explorer.
Unfortunately, this option did not work.
Thanks,
Clint
0
