Modify dimension arrow head?
Is it possible to modify the standard arrow head so that it is less pointy like this:
The standard arrowheads are as follows, which I don't like.
I'm super fussy about drawing presentation.
Appreciate any help/advise.
0
You can create a custom arrowhead.
Draw it and make a block of it, and then select that block as the arrowhead for a dimension style.
https://help.bricsys.com/document/_dialogboxes--db_selectcustomarrowblock/V23/EN_US?id=1650791317580 -
Fantastic !
Many thanks Anthony, much appreciated0
