Writing script for -pan up - specified amount
I need a script for panning up by a set amount, It works using -pan > Up, but it's only a small amount of movement. Is there a setting accessible by script for setting this amount?
thanks
You can choose the option to record or run a script, then select the relevant ".scr" file and edit in a text editor.
For example I recorded a script to pan up 20 units and this is the code it produced. Once you have recorded it, you can amend the numbers as required. Save and run.
-PAN
0,0
@0,20
_stopscript0 -
I read your question again, if you wish to use the -pan command manually to pan a set distance you can do that by entering the start coordinate e.g. " 0,0 [enter]" and the end coordinate e.g. " 0,20 [enter] "
0 -
Ah, of course - I didn't think to enter co-ordinates for the base point.
thanks very much0 -
Why not type p20 ? Ok that will give give an error message but you can make a little lisp defun that does just that, why not pu20, pd20, pl20, pr20.
(defun c:p20 (/ )
(command "pan" "0,0" "0,20")
0 -
Thanks, this is for part of a larger script. It includes, move selected group up 200, pan up 200, ungroup previously selected, end. This is so I can pull a grouped set of objects out of a larger assembly, work on it, re group it, then reinsert in the previous position.
0 -
Easy CHY CHX. Like 1990's
(defun C:CHX ()
(SETVAR "CMDECHO" 0)
(setq sn (getvar "osmode"))
(command "osnap" "near")
(setq x 0)
(princ "\nalters object in X direction")
(setq ht (getstring "\n What is amount of change: "))
(setq newht (strcat ht ",0"))
(while (= x 0)
(setq newobj (entsel "\nPoint to object: "))
(if (/= newobj nil)
(progn
(command "move" newobj "" "0,0" newht)
(if (= newobj nil)(setq x 1))
(defun C:CHY ()
(setq x 0)
(princ "alters object in Y direction")
(setq newht (strcat "0," ht))
(while (= x 0)
(SETQ NEWobj (entsel "\nPoint to object: "))
(if (/= newobj nil)
(progn
);simple routine to change objects in the z direction
(defun C:CHZ ()
(setq x 0)
(princ "alters object in Z direction")
(setq newht (strcat "0,0," ht))
(while (= x 0)
(if (/= newobj nil)
(progn
(command "move" newobj "" "0,0,0" newht)
)Ps may not need to ungroup can make anonymous selections (command "MOVE" (ssget) "" p1 p2)
0 -
Thanks so much - I'll give it a try.
0
