block insertion angle
Anyone having issues with blocks being inserted at an odd angle when not in WCS?
The block (any block) inserts at a rotation of 0 when in WCS. When I change to another UCS, the insertion is set to a rotation of 0, but not coming in at 0 (to the UCS)
Bricks version 24.2.03
I can reproduce this also, would you mind to create a support request about the problem? Similar problem has been corrected in V23, but it seems reappeared.
0 -
It appears to be corrected in v24.2.06
0 -
I still can reproduce this, if 'Specify On-Screen' option is used for insertion point. But when insertion coordinates are set via Insert dialog, rotation angle is correct.
0 -
Through the tool palette, it is currently faulty as well. It rotates the inserted block 180 degrees.
I submitted to support in a bug report.
0 -
Thank you!
0
