how to configure BIM schedule to extract ACAD object info
Similar to Civil3D schedule, i wish to extract info from AutoCAD objects, and update the table when object change.
How can I do it?
0
You can use fields in a table, you have not given any idea of the object details wanted. Please elaborate.
0 -
You can use DATAEXTRACTION to extract data from your drawing, including BIM and Civil data.
The command also gives an option to create a table on your drawing and link it to the generated .DSD file, which allows you to update the table with drawing changes.
0 -
I wish add custom properties as strings to any object, like civil3D's or AutoCAD Architecture's property set definitions
0
