Can´t change color of layers
Hello everyone,
BricsCAD was working just fine until yesterday, when I tried to change layers´ colors and couldn´t. When I try, it opens a small window (as it should) but there´s nothing in that window and the following message below:
How can I fix this?
Thank you all!
0
I received the same error message (don't remember what I was doing). Closed out Bricscad and re-opened the file and the error went away.
0 -
This Knowledge base article could be helpful in such a cases:
0
