Blockount to tabel including all nested blocks
Does anyone have a lisp routine to count selected blocks, including the besteld ones and put Theo in a table? Found nesten block count and block to table. But don’t know hoe to combine them.
https://www.mepwork.com/2018/12/block-count-autocad-lisp.html?m=1
http://www.lee-mac.com/dynamicblockcounter.html
Both from lee-mac
I do a lot of repetitif work and like to keep my blocks nested to speed up the proces and keep it easy to adjust.
Regards
Werner
Both from lee-mac
Regards
Werner
0
Maybe this works for you:
http://www.b-k-g.nl/bkg_countblocks.html0 -
thanks a lot,
did find it already, but didn't dare to install/unzip it due to different file-type
0 -
doesn't this work on a MAC?
Works on my Windows PC0 -
Hello,
apologies for bumping an old thread
i am looking for a routine that counts nested blocks
unfortunately the site in your link is down
The site is down. is there a new domain? or can you share the file and the select similar routine?
thank you and have a great day
0
