Hide Command
In Autocad you can draw objects, one on top of the other and using the HIDE command, to show only the part on top. For instance, you can draw a circle with thickness on top of intersection of two lines, so when you use the HIDE command, the intersection will disapear leaving like beeing trimed by the circle. This command is not implemented yet in Bricscad. Is thereany chance of implementing it ?
0
Implementing hidden line removal is a major development. It is considered, but not on short term.Kind regards,Hans De Backer
0
