UCS Icon Appearance
I recently had my ucs icon appearance change to what is shown in the attachement.
What does this signify vs. the typical orthographic ucs icon?
(forum having an issue uploading the image, link to image below)
https://www.dropbox.com/scl/fi/8on9387r1ievsfy8xk7lw/Screenshot-2024-08-19-064001.jpg?rlkey=41zro8c9abog2wsoicl1ktb8p&dl=0
0
Thanks for the note about file loading issue, it's forwarded to developers. Regarding your question about UCS icon appearance - such a view indicates that current view is perspective, not planar. To change it back you need to toggle the PERSPECTIVE variable via command line (type the variable name and set it Off), or by Perspective button on the View Ribbon tab/View toolbar.
0 -
Awesome…
Thank you!
0 -
You are welcome )
0
