Tool Palette versus Library Insertions
Share your experiences with tool palette block insertions versus library block insertions.
My experiences:
With the library insertions, I find that an extra EXPLODE is required to activate the AutoCAD dynamic variations.
I find tool palettes provide much more in the way of property and entity control at block insertion from the tool palette.
Thanks,
Clint
0
Pop menu's allow you to run the insert with a lisp behind the choice, same as the tool palette.
0 -
Great food for thought, Alan! Pardon the delayed response as a bit of life is happening now.
0
