Export to IFC moves some objects
edited September 2024 in BricsCAD BIM
Hi,
I have a model that looks fine in BricsCAD but when exported to IFC, some object gets rotated, what may cause this?
Under is a screenshot from within BricsCAD, you se the building with a section cutting it so that the inside is visible, everything is where it should be. On the left you can see a pie in blue and black that some disiplines has used to mark the world origin.
I export this to IFC and open the IFC-file in Solibri, the building shell has then been moved in all axis.
Any ideas?
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
