How can I remove or covert hatches?
Received a drawing from a structural engineer, and the kerbs to mark the edge of a road way are Hatches.
How can I convert these to 3DPolylines so I can manipulate them on the Z axis?
Thanks
0
Hatch objects can contain only a single elevation for this planar entity, and many times that value never gets assigned (is flat, 0.0). As such, you are not likely to be able to generate a 3D polyline. There are hatch boundary restore tools but it will be flat. If you want the best recommendations, post a small drawing containing a sample of your hatches.
0
