copying dimensions to other drawings
BricsCAD has an issue with copying dimensioning to other drawings. For example, in AutoCAD, if the dimensioning text or arrow was set to 0.18, it would appear the same size in every drawing. In BricsCAD, 0.18 can look as large as another drawing where it’s set to over 2.0. Moreover, when copying dimensioning to another drawing with different settings, it automatically scales down to a smaller size, which shouldn’t happen.
0
It would be useful to get example drawings to reproduce this and look at their settings. Do INSUNITS have the same value in both source and destination drawing?
0
