Bimtag for mechanical components
Dear all,
I have developed a piping model based on custom components inserted into Bricscad Mechanical as smart components. I then have attached this as an _XREF into a building model. Now I would like to label piping parts within the sections generated using _BIMTAG. I does not work out of the box. So my question is: how may I access mechanical attributes from within Bricscad BIM and pass them to _BIMTAG. Any hints are highly welcome.
Kind regards
Sebastian
When following the docs I may define a multileader and hence a field within. From the drop down menu it seems that mechanical info is not available.
0 -
Hello.
From my testing, only BIM properties are available to be added to a MTEXT inside a MLEADERSTYLE.
Given this, the entities should be first classified as BIM entities, most likely using types from the Building Service Elements category.
0
