New Ribbon Style in V23/24 is wider then older version
Hello,
where are the possiblilities to get also the same amount of Buttons ord dropdowns to the new version. There is more space between button and separators, but i find no possibility to reduce this space. Thank you for your help.
I create the button with vb.net.
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
