Help with running multiple macros
I have this function that runs a bunch of macros simultaneously. For some reason when I run each one individually, 1 by 1, they all work fine but when I run this code the "fixtrees" macro doesnt execute properly. I was thinking maybe I need to add a delay between each one maybe? Any other ideas would be much appreciated. The code:
; macro that runs all necessary jobs with one function
(defun c:startjob ()
(command "._fixblocks") ; Fixes all block settings specified in that file
(command "._fixunits") ; Fixes all unit settings specified in that file
(princ "\nBlocks updated.")
(princ "\nUnits updated.")
(princ "\nAll macros successfully started.")
(princ "\nReady to begin!")
(princ "\nType 'startjob' to run all macros.")
Hello.
You could test with adding a "pause" after each call of the (command) function.
This would ensure that the command finishes before the next line of code is executed.The "pause" could be something like:
(while (/= 0 (getvar 'cmdactive)) (command pause))0 -
The pause simple (alert "at step1"), (alert "at step 2") and so on. Sometimes have like 5 steps trying to find a bug.
0
