QuickDraw very slow
Hi, new in BricsCAD, but I found that quick draw is very slow, which feature I need to turn off to speed up my drawing?
I tried to model a 2D drawing imported from old files, but when I use QuickDrawing Bricscad turns very slow, probably because of preview dimensions and other preview features.
Welcome!
It looks like you're new here. Sign in or register to get started.
  • Hi
    Could you file a Support request , including your .dwg file, and information on which version you are using : via this link
    This will allow us to investigate further.
    Thanks!
    Best regards,
    Ruben
  • hi,
    are you working on drawings with a lot of parallel lines and hatches?
    We discovered an issue with Quickdraw and Bimwall on this geometry and are working on it. For now, best workaround would be to turn of all hatches if possible.
  • here the sample
Welcome!
Welcome!
