vla-put-StyleName with dimension
Hello everyone
I have several dimensions in a drawing, and I want to change the dimension style of all selected dimensions. In Autocad I have this code that works fine:
(SETQ SEL (SSGET "X" (LIST (CONS 0 "DIMENSION"))))
(IF SEL
(PROGN
(SETQ CONT 0)
(REPEAT (SSLENGTH SEL)
(vla-put-StyleName (vlax-ename->vla-object (SSNAME SEL CONT))) "style1")
(SETQ CONT (+ 1 CONT)))
) ;REPEAT
) ;PROGN
) ;IF
But in Bricscad it does nothing. What am I missing?
Thanks
And, if I add:
(vla-Update (vlax-ename->vla-object (SSNAME SEL CONT)))
nothing happens
Maybe try
(vlax-put (vlax-ename->vla-object (SSNAME SEL CONT)) 'Stylename "style1")
0 -
thanks Alanh.
in fact, it appears as if the dimension style has been changed, but the text does not appear above the dimension line, as defined in the style. If I change the style manually, it does update.
Any suggestions?0 -
Hello.
It seems that there is a typo, either here or in the main code.
The call of (vla-put-stylename) should be:
(vla-put-stylename (vlax-ename->vla-object (ssname sel cont)) "style1")Before "style1" there should be only 2 closing parentheses.
This version worked fine in my testing.
0 -
(vla-put-stylename (vlax-ename->vla-object (ssname sel cont)) "style1") ⇒
I have tested it on my bricscad 23.2.03 and it really doesn't do it as expected.
before:
after:
and the text is not above the line…as defined in the dimension style
Thanks Virgil and Alanh. I continue to search for the error
0 -
Hello.
I am not sure about it, but the case might require clearing some existing dimension overrides.
So, after updating the dimension style, this is something you could experiment with:
(command "_dimoverride" "_c" sel "")0 -
thanks i'll try
0
