Create wall using BIM space boundaries
I tried use extrude polylines to create walls fastest as possible but sometimes appears errors, errors like bad rotation walls, etc.
is there any possibility to create walls using BIM Space boundaries (3D solids) as walls? I mean wall without errors, anything equivalent to insert a wall manually.
PD: take as reference Dialux, this software can import spaces and create walls, not perfect but help a lot.
0
I think yes. But have not tried ….
0
