Spaces in scripts
Hi!
I have a script that contains the following commands:
-LA ON
layer name
The problem is that the layer name contains a space and this is interpreted as enter. I have already tried putting the name in quotation marks, but that doesn't work either. Does anyone here have a solution?
Alternatively, a script that replaces all spaces in layer names with underscores would be helpful.
Thank you!
  • Hello.
    You could use double quotes.
    This worked fine in my testing.
    -la on "Layer 01"
    To clarify the white spaces:
    -la¬on¬"Layer¬01"¬¬
    where ¬ represents a space character.
  • I tried that before and it didn't work but now it works…🙃🙃
    Thank you!
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
